Got a big oak log that's been down for about a decade, could be fun. Might be interesting. Its still rock solid. Might need a decent pressure wash and potentially a metal detector to make sure none of them nasties are hiding in it.
2 hours ago, gobbypunk said:
Almost maxing out my new mill took some getting on there but loving it DSC_0866.jpegDSC_0867.jpegDSC_0869.jpegDSC_0870.jpeg
Max out the mill with that log 🤣You can go miles bigger than that mark as looking at those boards no wider the 500 mm ?
Edited by topchippyles
Hi Lez you are right but I wrote that just as I got the butt on the mill ,but the mill is vibrating a lot and since I changed the band the tension will not stay the big handle was vi rating loose  ,any ideas
  • Sad 1
Sounds like you have not torqued the blade correctly.It will vibrate like hell when cutting if the tension in not set right.
