Twin rope snatching
munkymadman
I saw one of reg’s videos with two pulleys two ropes and the seperate bollards for snatching. A 16mm line was snapped in the past. So could this be avoided by doubling up. Rope on rope is a no no, but if they’re running at the same speed can they both go off the same bollard. I’m assuming that would be a disaster. We have a couple of grcs’s and a number of flying capstans. Any configuration ideas that doesn’t involve buying a double bollard?
I think running two ropes of one bollard is not a good idea. Much to much chance of the ropes rubbing against each other under load.
I have used two separate bollard type devices on the odd occasion I needed two ropes on the same section of wood and there are two bollard lowering devices available.
I have seen some massive pieces caught on a one pulley system. It's really important that with big loads the rope is allowed to run.
It is also important to estimate the loads involved and not go mad!
I’ve used two bollards a fair bit for doing large limbs or double rigging. But on a spar it would have to be identical otherwise it would favour one rope over the other. I like the M rig snatching idea. But I reckon your right that maybe a ring would be better than a pulley. I guess I’m considering those times when it gets low and fat without much room to let it run.
Afraid I haven’t got the luxury of choosing which ropes the company buys. Hope your well too Carl. I’ve just arrived home :)
Put a block on your piece you are rigging as well, this increases the rope in the system drastically and creates a 2-1 system, works really good especially on dodgy trees as it reduces shock loads.
Climbing arborist on YouTube has a good video about it.
woah woh woaaaaahhhhh......you broke a 16 mm double braid lowering rope?? Jesus, that takes a chunk. Have you considered knocking them out a smidge smaller ?? [emoji12]
11 minutes ago, Treerover said:
woah woh woaaaaahhhhh......you broke a 16 mm double braid lowering rope?? Jesus, that takes a chunk. Have you considered knocking them out a smidge smaller ?? emoji12.png
Easier done than you imagine - a decent lump of beech & a numb groundie & your breaking shit.
