25 minutes ago, Jase hutch said:
GreenMech have done it on a 19-28 SafeTrack for Germany , compared to an electric winch it was slow.
surely be faster than an electric one hydraulic is usually faster
Just now, woody paul said:
And cook you battery if used for long pull.
I had an electric winch on a couple of 4wd, on long repeated pulls (pulling branches out of a lake) it sometimes overheated and stopped, always started again after a cool down, never cooked a battery, of course I ran the engine on TO all the time.
The hydraulic on the Land Rover was good but very slow, repeated pulls you die of boredom.
If you want speed you need pto powered.
Got an electric winch on landy and it do's battery in quicker then normal use. Has a chipper got a big enough alternator to keep up with supply need any way.
There are a couple of hydraulic winch's out there which will pull you off your feet as they are fast.
1st things first is the pump a vane/gear pump or a piston pump ? 2 different pumps with 2 different working pressures, check working pressure on chipper and then check pressure on your selected winch, being a tracked chipper it is most likley to be the higher pressure piston pump but it may all so have a gear pump on the end of the piston pump allowing 2 different working pressures on same machine ,
