No wonder this eucalyptus  is so tough judging by way the fibres look like a zip?
slim
I came across some logs like that years ago, always wondered what they were.
Wish I could mill some.
[emoji106]
slim
this would be called rippled eucalyptus and the figure is fantastic in that lump. such a shame it all goes on the fire.
2 hours ago, Steve Bullman said:
Never knew either of those things.
Hornbeam is also used for skittles for the same reason.
Interesting also that the Romans used to use Elm for water pipes
hornbeam is only use for one sort of skittles. it's called old english skittles or london skittles and there is only one pub left (possibly in the world) that still plays the game. the freemasons arms next to hampstead heath in the cellar.
other timbers used for skittles are beech, sycamore and boxwood.
Well blow me down, (just like the Hornbeam)  the amount of interesting facts I have just learned from a fairly innocent post about a very hard lump of wood.
And I thought that I was old enough not to discover many new facts about the woods.!
Just shows what a great site Arbtalk is,  a veritable fountain of knowledge.  Thank y'all
Playing skittles many people try and tell me that the pins are made of apple wood. Even whenI’ve told them I cut sycamore timber for skittles they don’t believe me.
21 hours ago, sime42 said:
Hornbeam was used to make the teeth on gear wheels in mill machinery, because of its hardness and strength. Before iron was readily available.
Whilst Elm was traditionally used for the hubs on cartwheels, due to its toughness and resistance to splitting.
The old craftsmen were certainly far more in touch with the prcoperties of natural materials.
Just found this site where it states that not only Hornbeam , but Cherry and  Apple were also used in making gears inside a cast iron frame. particularly in Mills.  They are much quieter too.
http://www.newhallmill.org.uk/gears.htm
Interesting. So I wasn't quite right, they were using wood for gears at the same time as iron. It was more for quietness and easy of replacement.
It shows how hard the wood is anyway if it was rubbing against iron.
There was apparently another reason for using wooden (hornbeam) teeth in the gears.  It was a major safety (and cost saving) feature.  If for some reason (say a large stone) the mill got jammed, with all that power, cast on cast wouldn't have a good outcome - there is no clutch !!!  Alternatively replacing a few wooden teeth you'd be operational again within the hour.  I attach a photo showing it was usually the big (drive) gears that had the wooden teeth.  The smaller gears are iron.
BTW the pillars are (apparently) sweet chestnut - no idea why - probably something to do with load bearing ???
Edited by ABtrees
