On 01/01/2019 at 16:10, westphalian said:
having bought a Sugihara Pro Solid 20″ 3/8 bar with Stihl Ripping 3/8 .063 chain i just returned to my original Lo pro set up. ok it might snap from time to time but it cuts like a hot knife thru butter. quicker in the long run just repairing the links 3 or 4 times a year
Yep I do love the love pro - it smoothly devours wood. Although messed up today - did a first cut last night, came back to the job and went to cut the next plank and mill kept trying to rise off the log... strange I think and come from the other side - not much better.
Put the first cut rails on and oh - looks like my flat first cut was not that flat - re sawed it and bingo - x6 2.5" 6ft planks all super flat in a couple of easy hours work.
I was out yesterday and 2 snapped. one after only 30 minutes. the bar looks fine etc etc. I have about 4 or five low pros and been milling with them for 2 years and replaced links when they snap but to be honest I have come to the conclusion they are perhaps not robust enough for several hours continuous milling. when I get round to it I will post a video of the 2 different systems in action, photos  and ask for views. oil on max, new sprocket.
any advice more than welcome
I’ve changed my mind about using the lo pro regardless. Ok I only need to wind the saw thru the wood with two fingers and the 3/8 is a lot slower but when they snap it takes a good 10 minutes removing the cradle/gib and replacing the chain not to mention the time it takes to replace the link. I shall keep em in reserve. Will post a pic when I finish work
I wondered that. I will try and mark the next repairs.
edit. just realised, no need as you can see the parred rivet anyway?
Edited by westphalian
Also could over tight, it looks like where I marked 1 it’s got a fracture starting, 2, is domed and different to the rest of the rivit heads. 3 looks a bit the same as 2 and A bit tight ?. 4 looks a bit peened or just bashed.
thats my first observations
This one is original. granted my repairs are not perfect but remember it only needed repairing in the first place due to snapping?IMG_2308.jpg
