The bioremediation properties of trees is interesting when you start to look into it, they even improve the water quality of road surface water run-off by trapping copper and brake lining dust, before it gets into watercourses.
They are gonna save the planet! Growing faster to take up the CO2 making the wood lighter. Win win. I will be able to lift 8ft stems onto my mill without a block and tackle in 50 years
But doesn't it just cycle back to the soil when the wood rots/leaves fall off every autum so whats the advantage?
Unless wood/biomass is harvested but then what do you do with it?
Edited by Stere
I don't know enough to answer that question, but I think that it depends on the pollutant. The chemical composition of some things changes to less harmful constituent parts etc.
Basically, trees/vegetation are good. I seem to remember of a big project in Manhattan a fe years ago where surface water ran through planting beds before flowing into the Hudson to clean the water. Previously the run off from surface water was so bad it was killing fish.
