5 minutes ago, difflock said:
Nope, the impervious "blue" clay underlies the peat in this area, i.e. where we built the house had been  "rank moss", but long since cut-out for peats(turf), so the remaining 500-600mm or so of peat was to be entirely removed, then the underlying clay scooped out and built up to form the banks.
It should have been a simple straightforward operation  .  .  .
I see. No contract of works to make sure he did do what he was supposed to do before paying? Only asking, not trying to wind you up further to be fair.
Some things are just better done by yourself even if it takes a bit longer. But if it isn't lowering noticeably now then hopefully its not too bad.
On another note there seem to be differing ideas of what is good or bad to have in the pond. Back in the day there seemed to be no understanding of the value or logs or other things being in the pond, but in fact for biodiversity reasons logs and other things in the pond make quite a big difference to what species and insects end up being able to live in the pond and surrounding area.
With all the heavy rain over the last few months we had to lower the level of the pond as it was getting way too high. You can see how much water was coming in on a regular basis with this photo.
36 minutes ago, difflock said:
clay scooped out and built up to form the banks, with said banks built entirely on the stripped clay base,
I've a pond which was excavated in chalk on the woodland I volunteer on, it was lined with clay but plainly leaks as it empties in the summer. how deep does the clay have to be to seal a pond?
I try for 300 MM minimum  very well compacted, sheeps foot roller is ideal, timing is crucial clay needs to be dry enough to not rut  but wet enough to squeeze tight you cannot over compact the clay. Also dig a cut of trench round the outside of the pond 600 MM deeper than the pond base excavate soil then back fill and compact to cut land drains and stop leaks from old roots etc.
Edited by dumper
Spelling
No paperwork, it should not have been needed in this local community, and despite making enquiries locally, and indeed furthur afield, for a D6 Bulldozer, after about 2 lost years, I ended up using the local firm that I have used this past 20 odd years, but they have grown too large, the son who runs the business was away on honeymoon, I did not get the particular operator I had specified, and the "main man" on the job was the "canny" father who spent as much time on a mobile ph running the business in his sons absence, combined with them choosing to turn up when it was raining/too wet and then machinery breakdowns and oddball short days/part days.
All in all the perfect shitstorm, which was why I cut back on my planned larger size and chased them away.
But the invoice was only? for £1825.00 plus VAT.
We had a site meeting to discuss very recently, and they could see no issues with their work, or work ethic!
I will , I suppose, pay the dammned invoice, which I only got a couple of weeks ago, despite my repeated requests for same to get squared up.
I have since switched to using another local "one man band"(with a selection of different sized diggers), at least that way I know who I will be getting in the drivers seat, and he invoices promptly with all supporting documentation.
Edited by difflock
I am most envious!
Quite right. Well I hope it all works out well in the end. Despite all that though you will have a pond.
Do you fish?
I am most envious!
Well that is on the site I work at. I wish I could own such a good thing. But having worked here for 20 years or so I sort of consider I own it a bit. At least I can look after it and know I helped. It's a 2.5 acre pond manmade as a boating lake back in the day. Trouble is there aren't any boats anymore and at some time someone took down the old boathouse so some of the historic features aren't there anymore.
Maybe one day I can get the boat house built and get a few boats back on the pond.
I lifted a manhole lid "downstream" of the pond this afternoon, there is only a trickle of water coming in from the direction of the pond, and some of that could still reasonably be natural seepage from earlier rainfall, if I had a while tomorrow or Sunday, I will try and find the 2, perhaps 3 number  tile drains that run into the back sheaugh, since they drained the field the pond was constructed any other leakage should be easy to find and quantify.
This evening I lit a wood fire in a big 500mm dia cast iron saucepan, set on top of an upturned galvanised mop bucket, the perfect improvised fire-pit and sat out until just now, watching the trout rise  while spotting the odd Bat flitting about.
Wi a big mug o tay.
All quite perfect.
Landscaping, after a fashion, I was moving the flags anyway, and thought they would make good ballast to use the linkbox as a rudimentary land-leveller, tis a bit "tiddy" tweeking the ram to finessee the cut but  .  .  .see images.
