Basically anything that will catch fire - sawdust is used in bank safes cos if you disc cutter it or oxy-torch it - It catchs fire and fills area with smoke , K
The best anti theft idea we came up with is:
A very high powered tweeter from a sound system in a steel mesh box installed high up.
With a remote on/off and a light/movement sensor.
Would wake everyone in a mile radius and deafen any intruder.
or phone jammer and night sights, then dangle some bait
Nitroglycerine
Pros:
Can be made with kids chemistry set
cheap
1 kg could level a building
Cons:
very unstable (direct sunlight can ignite)
100% ilegal
How to make:
1-Cool 13 mL of nitric acid using the ice created by the
refrigerator.
2-After it has cooled, add to 39mL sulfuric acid (99% h2so4),
mixing very slowly.
4-Cool the new mixture to 10-15°C, which we can measure with
the thermometer already “invented.”
5-Slowly add enough glycerin to cover the entire surface of
the acid.
6-Keep the solution below 30°C.
7-Stir gently for ten minutes, then the nitroglycerin will
form as a layer on top of the acid solution, while the
sulfuric acid will absorb the excess water.
8-Filter out the nitroglycerin and place it in sodium
bicarbonate, which will neutralize much of the acid remaining.
This will help to stabilize it.
10-Now slowly and carefully remove the nitroglycerin from the
bicarbonate.
Edited by chuck norris
Chuck,
there are many better chemicals for this idea.
Nitroglycerin is stupendously unstable.
Also the technique you describe has some very unpleasant side effects.
Also under current anti terrorist legislation, you're looking at serious time in prison.
It is a tempting thought though...
Anyone on here ex army?
Are thunder flashes legal to own?
[emoji848]
