It is hard to argue with her now her mind is made up!
She just needs a small saw for cutting ivy off some of our trees.  I bought her a cordless reciprocating saw but she say it is too slow, heavy and the battery is pathetic.
Buy her a Silky I hear you cry!  Tried that , bad result
She has the leggings, gloves, helmet and boots but I am still worried about kickback, particularly when messing about on the horizontal plane with multiple strands of ivy, some over three inches diameter at the base
I bought this saw horse off eBay to resurrect my old Dolmar electric which has no kickback safety device.  The saw horse does have a top cover which offers protection and also having seen the Alligator saw sold by Tesco which has a similar top cover is there anyone selling a lightweight top hinged cover to retro fit?
It would need to be lightly sprung to keep it in position.
Are there any obvious disadvantages.  I have no problem with the Dolmar going through ten inch logs or more.
Even if I cut a plastic chain guard in half and hinged it near the handle it would be light and offer protection.
i was wondering in view of all the accidents with kickback why there is not such a device readily available bearing in mind most amateur chainsaw users only cut downwards.
Edited by Billhook
Spelling
Hi I am sure there is an attachment that bolts on the nose of the bar especially to stop kick back or get her a carving bar as the kick back zone is so small they very rarely kick back I have only had one slightly kick doing very odd cuts on some piece of work , yeah the more I think about it the better it sounds , why not ask some other carvers on the chainsaw carving bit I am sure they will agree, hope this helps
Cheers Mark
2 hours ago, Rough Hewn said:
Stihl cordless chainsaws are great. Light and easy to use. Less torque than a petrol saw, so less kick back. (Less not none).
The little Stihl 120 cordless is what I had in mind. Just wondered if there was a device on the market as I have described to fit over the chain
Hi, are you thinking of something like a motorcycle chain guard... if that's what your after it would be real simple to make out of a bit of flat bar and just drill a couple of holes in the bar to mount it, cheers.
I've got the MSA 120 and use it a fair bit in the garden pruning woody stuff as well as cutting some decent sized logs. I've never noticed any kickback which I think is down to the very fine PM3 chain as well as the narrow nose, it is also less grabby that bigger toothed chains on thin material.
I like the narrow nosed bar for pruning jobs, I would wonder if a guard might make someone more likely to have a problem if they catch the guard on another stem or something?
3 hours ago, scbk said:
If it's just for ivy, would you not get away with a good set of loppers? Cut up to 2" thick?
Tried that but although easy for me and thee, she is not strong enough to do a days work with the loppers.
Weaker sex!
