AndyChalmers
Japa 370 processor premature bar wear
10 hours ago, oldoaktree said:
Is the feed belt still pushing the timber up against the bar as it’s cutting?
no, feed belt pushes timber to the length stop.  then belt stops.  bar is pulled down, chain starts, then cuts.  Belt does not start again untill I make it start.
Share this post
Link to post
Yes I know how it works used to have one . What I mean is once the timber has hit the stop is there tension in the feed belt so as you cut the timber is getting pushed forward ever so slightly from the tension in the belt .
On the palax the stop retracts once the blade starts to come down meaning any tension in the belt disappears
Share this post
Link to post
Ahhh I get you, im not sure.  I am cutting longer & heavier lengths than I used to so its possible the extra weight is making the difference.  I'll check it out.  Thanks for the pointer
Share this post
Link to post
Just seen this thread.
Sorry for the late comment but I have had the exact same issue with my Japa 300.
It turns out that it is down to the prolite bar. Its just not made for the rigours of a processor.
I switched to control cut (versa cut on the 370) and a massive improvement.
Hope this helps
Share this post
Link to post
Hope this helps
Thank you for your advise, I never got to the bottom of this.  Been using my spare processor as 370 did my head in.  So basically yours was cutting diagonal and wearing the bar out fast?  So the Oregon Control Cut bar & chain helped? or just the bar?  Any details greatly appreciated.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
