Just a wondering about the life expectancy of drive sprockets. When i was first taught about using saws a rough rule for replacements was 3 chains to a bar - 3 bars to a sprocket. Based on chains and bars getting worn through use rather than abuse.
Had look at 261 at a company, its about 18months old - the sprokect was really worn - my guess is the chain has been run at the wrong tension too much,
a 550 has  a worn sprocket as well but that saw had the misfortune of being handed to a very special kind of worker to use as his own saw as everyone got annoyed with him wrecking all the saws and just leaving them back on the shelf.
A 440 thats been with the company a good few years and seen a lot of use,  hasn't had a sprocket replaced on it and the one that was original is in good condition.
Now is this a case of user causing the wear or are some sprockets just lasting longer?  maybe built of things other than oriental tin?
The general rule is that all MS261s and MS362s that come in get a new sprocket kit. All others get a new rim or a new spur sprocket now and then.
I still don't understand why the 261s and 362s eat sprockets - I believe it is a cunning plan by Stihl to make money on their Satan's creations. I think only one 261 escaped my rule in a good number of saws!
If the end of the spur gear has indentations then it is time to swap it!
The MS261 must be one of the worst sounding saws - the exhaust note goes right through my head!
My old rule of thumb is,
3 files to a chain
3 chains to a bar/sprocket
3 bars to an overhaul.k
( to guys who think the bar should last the life of a saw- but then in their hands that's usually 1 8months ;P )
3 files to a chain
Expand
What do you mean by overhaul?
  On 08/02/2018 at 19:19, Dr Stihl said:
Stihl MS261 sprocket problems should now be a thing of the past, new rim sprockets were introduced late 2016 and no problems since, unless the crank was worn by the previous sprocket.
Expand
+1 . From a very reliable Stihl source the clutch drums were the problem all along (a problem with the metallurgy) now resolved.
Read more
