Heres a couple of pics of a soft-eye pulley saver I just knocked up. I used to make them with hose over the outside of the eye but lately have been using rubber bungee cord like whats used for the big-shot and it works a treat - retrieves every time and no chance of unseen wear inside the rope like when wire rope is used as a stiffener.
Where do you get the bungee cord from mate?
Hey mate, I am in Australia so not much help to you but I get it from 'Clark Rubber'. They are a wholesale rubber supplier and you can buy the bungee cord off a roll by the meter.
The stuff I use is about 10-12mm thick and is a bitch to insert into the rope.
Edited by browncow
Really nice idea with the rubber inner mate. Been looking for something similar my self to use. Not found anything yet although I do get distracted easily on the Internet?! Haha.
As far as wear goes with the wire insert,I used one of mine for well over a year and then dissected it. No wear inside from the wire at all. The stuff i use is 5mm with a plastic coating round it.
I like the rubber idea as it will have memory. I need to do another as I knocked one I made and knocked up another quickly a forgot to insert anything... Doh!
try nitrile, the stuff they make o rings from, little memory, uber stiff yet flexible. And as its solid can be tapered nicely!
My sneaking suspicion it might be what the pulleysaver uses but I won't cut mine open....
have a look
If you know anyone who uses big oring i.e plant fitter that may be a good point of call for free bit
