Edelrid are doin some good kit right now,decent harnesses and there new spikes get good reviews.
At a tenner a pop though for biners that arent triple lock,im not convinced id need em that much :|
i just use normal steel rigging ones, i prefer to have locking ones but i guess the ones in the picture are very light so good for tons on your harness.
  On 01/01/2018 at 21:20, TIMON said:
Dmm revolvers are good but there isn’t a wide opening on them.
Don't use revolvers because it's a nylon bush inside which will melt if you run it at excessive speed down the rope and just become an expensive wire gate.
Tempted to order a few of the ones darrin posted in the op as that steel insert should make them last considerably longer without being heavy all steel.
Made in Taiwan. I was expecting a EU production .
Big weight difference compared to steel only.
I normally wouldn't bother so much but having seen the Monkey Beaver Speedline Kit .
I wanted something similar.
Read more
