First Aid Shears Versus Chainsaw Trousers?!
Not not long ago I went on a workplace first aid course and today I bought a first aid kit for my car which contained a fairly hefty looking pair of emergency shears.
It got me wondering if these shears would actually be suitable for cutting away chainsaw trousers in an emergency. As in getting through them swiftly with out a struggle or damage to the shears. Anyone had the misfortune of having to do this? Or tried it for training/research purposes?
Edited by Sambo
When they cut my A class 1 Husqvarna trousers off me the shears went through all layers in one go without a problem. I'd lost the use of my left leg following a crush injury and my pelvis was fractured (cracked rather than broken apart). The nurse cut straight up the front rather than lift my leg to get at the back with no protective layers.
Sadly - Openspaceman, had just same experience getting smashed off my motorbike , wearing nerly new ballistics , n the paramedics scissors when clean through the trousers - I cryed ! K
Yes I was a bit miffed. It was nearly 20 years ago
Are you advising against taking up motorcycling again :(
Sounds reassuring coz I use type C trousers as a rule! So it would be cutting through ballistics wherever!
How's your leg now?
How's your leg now?
Slight dent  just below the groin but other than that no consequential effects,  took a few weeks before I could move the leg as the femoral nerve was crushed and took a long time to re network. Steering wheel still a bit misshapen isn't it @farmer rod?
  • Sad 1
