I've been asked to look at this Ash with regards to it's safety. It's on a public footpath and the bank that it is on has been eroded away leaving the roots exposed. It has obviously been happening over a long period of time and the tree has put out roots to compensate. In the second picture there is a large root that reaches from the Ash tree to the tree in the foreground. I think it might be worth airing on the side of caution and have it down but what are other peoples thoughts as to whether it should be felled or not?
That looks well adapted. One consideration is that wood is stronger under tension, so there's less risk of the roots to the back of the tree shearing and failing.
I think felling it is unnecessary, based on thise photos.
I found the THREATS system to be quite useful in these sort of circumstances, gets your mind thinking.
Just work your way through and see what the score says.
I often find it difficult to decide between which score to give it, so sometimes end up doing 2 or more calculations.
Hope this helps
Let us know what you come up with.
Regards Neil
Over a building or suchlike perhaps, over a woodland footpath with little footfall I'd do nothing.
Armchair quarterback stuff of course.
Agreed Sir Dempsey.
It's bloody good firewood though....[emoji849]
