planning to put a new body on the tipper and wondering if I need a roof, its a crew cab tipper with the back seats removed, creating about 2 sqm of space, also plan on fitting storage boxes to the chassis for fuel cans etc, there is a large area between the chassis rails from the cab to the rear as well so no need for tools in the tipper section. Is there any other reason for having a roof?
The chip box is quite high and I'm very careful about not over filling so can't see much chip escaping. up until now I've been chipping into a mesh sided ifor with no problems. I probably would put a hinged roof on it if it anyone has a simple mechanism design for one?
As others have said simply there to stop excess chip flying out again, although with a powerful chipper we use a tarp as well.
We had ours hinged, so it can be lifted write out of the way if we are loading by machine99f56066b28f929b0da1ea7493028afa.jpgdb385b1bda4da9b26960e3f878bcd919.jpg
Hope this helps
Regards Neil
Read more
