fill it with water:thumbup1: stihl saw job
did you fill it with water then leave it for a while or fill it and get the cutter out when it was full? i also heard they are difficult to get the valve off? i am looking to build one for the workshop
  • Replies 22
cut the coller off, unscrew the valve, leave for a while whilst the bottle is upside down,,(gas is heavier than air)then fill and cut whilst full of water
How do you get that empty of gas BEFORE you cut it open? i heard fill it with water
take out valve and disc cut,never used water myself,only used water when welding petrol tanks:ohmy:
never had a prob
(not in a garage but a barn)i use this.. just keep fuels and oils tucked away:thumbup:
in a garage just the small calor gas fire.. easy to use and turns off if you need to go out:thumbup:plus there cheap to run
how did you go abouy opening the bottle ? you didt just sove a grinder into it
