Prices vary from area to area.
You wouldn't get away with charging London prices in the midlands.
I stopped giving hourly rate a few years ago as people expect to pay only for the milling time not set up.
Day rate for chainsaw milling is £200-£250 I know some ask up to £400, if they can get good luck to them.
Depends on the job, but normally,
Flat day rate £325
2 guys, many mills and big saws, insured for milling.
8hr day.
Run motomix and stihl bio.
Generally travel 1-2 hours each way to work.
Time in workshop grinding 48" ripping chains, filing bars, cleaning etc.
Not much profit, but if you bring a slice home each time, you get a good stash.
£400 is more reasonable, but I'm sure would put people off.
Hope this helps.
[emoji106]
Hi guys, personaly I hate those 'how much to quote for this job' threads but what would be a fair average price for milling services with an alaskan?
I hate those threads where folk give virtually no details to allow others to answer them ;)
Break it down some! What saws you got? What mills you got? What experience do you have? Where are you based?
All of that has a bearing on what price you can charge.
type, quantity, and condition of timber, size supplied and size required, acsessability and condition of "yard", these all have a bearing on the cost, as well as your kit,
We quite regularly get enquiries about a mobile chainsaw milling service - customers also often comment that they'd arranged someone to come and do a days milling but no one turned up.
I reckon if you don't end up doing a job it's because you've priced it too low!
As a rule of thumb - if you have a good sized set up (MS880 or equivalent), a vertical mill/saw and know what you're about I'd say £320-00 for a days work is around the right price.
If there's x2 of you then £420-00.
Thats pretty strong money for just 2k of kit Rob :confused1:
