  • Replies 67
Could be the fuel filter
I am missing something probably but how is the fuel filter ( on a brand new saw ) going to make it hard to pull over ?
You shouldn't wash any part of the saw with water, the water has probably rusted the needle bearing locking it up to the crank. It can happen overnight and the first sign is the chain spinning when you try to pull it over....unless the brake is on when the saw becomes very difficulty to turn over.
Pulling the plug, taking the B&C off and pulling it over should reveal the answer....if you know what you are looking at!
assuming the saw was running ok prior to your cleaning it has to be somthing you have done, so chain brake actuated prior to re fitting?
Yes all was fine brake/chain all
Once refitted. Then this. Hmm??
