Lawnmower battery flat, can I use a car battery charger to charge it?
Sent from my iPhone using Tapatalk
How many cells has it got, 3 for 6V 6 for 12V? You'll soon fry a 6V battery with a 12V charger.
It says 12volts and reads only 2 volts at the moment and my car charger is a diesel charger up to 1900cc got it on slow charge
Essentially if you let a 12V battery fall to below 11V you compromise its life greatly. Stick it on the charger and wait.
I'd be surprised if you could bring a 12v battery that is reading 2v back to life.
Me too, discharge below 10.5 Volts for lead acid battery is terminal
Those CTek chargers are pretty good & help prevent sulphation
I would charge it at a higher rate - more than trickle - to try and help reverse the effects of deep discharge but would be surprised if it does hold charge. Keep a check on the water level and loosen the cell tops to allow gassing.
N
Edited by NFG
