So hows them vented bags going?
18 stoner
Been looking into getting 0.75cube vented bags, and looks like best price i can find is £5.60 +vat delivered.
Not too worried about the price if they give good return, obviously need to be used a few times each, so just wondering for those of you who have had them a while now, are they lasting?
Anyone with tips or advice on looking after them would be great, like are they affected by UV like builders bags, and do you leave them with customers, if so what sort of deposit are you charging etc.
  • Replies 55
I have used them this year, I filled them with stuff that was about 6m to a year old and it has now been in the bags for 6 months or so. Firstly they do work: no mould and logs are dry. secondly they are degrading in the sunlight, the ones at the edge split easily, so I'd be wary about using them again and again. unless you keep them under cover.. which may restrict airflow.:001_smile:
are the straps holding up tom?i really think its the way forward, as it saves a lot more handling. but if they fall apart then that isnt much use
The straps are fine, the weak point is the vents themselves as thats where they're thinnest.
