Lights and front mounted equipment
Gray git
Or headlight /indicator setup off a telehandler front mudguards. Weld a locking hinge on the light bracket and onto the rear of the winch plate either side. Can be folded back behind the winch when using winch, then swing round to position to go on the road, could always fix a couple of side market lights on the side of each headlight assembly, then all sorted
have a look on eBay for job 3cx style headlights mount them on a bracket or cage them in and hey presto your legal I would also find some way of disconnecting the front lights on the tractor as I think the reflection off the back off the winch would be a pain in the arse
Not sure about the valtras but on some tractors when you plug extra head lights into the 7 pin plug on the front linkage it switches the tractors head lights off automatically
Chris
Valtra are easy, switch on dash turns them off and flips up to cab lights that are Road friendly with high and low beam controlled on stork same as fronts, also found a handy little plug behind bonnet that comes live when you do this where I can plug in the marker lights.👍
Sent from my D5803 using Arbtalk mobile app
