Use the crane legs and two big rings to lift the front, then cut some chunky lengths of timber to prop under the chassis about halfway along. Lower the front down, the back should come up on its own.
A truckist`s :) must have kit, PCL socket screwed into one of the air tanks, an air hose long enough to reach the furthest axle, a tyre inflater that locks on to the valve, a 20ton air jack and a 12/24 volt jump pack. Air bottle jacks make easy work of jacking up a truck and can be used manually in the absence of air.
06184 Heavy Duty Air Hydraulic Jack 20 Ton Bottle Jack Pneumatic Lift Ram Car Va | eBay
Bob
How do you propose to straighten the chassis after doing that with a load on?
Bob
Hi Bob
I have an airline set up for the 7.5t which is very handy. I'll look for a suitable valve on the 18t.
I was looking at a 20t pneumatic jack with a manual option as well.
Cheers.
http://www.cormacktreecare.co.uk
