Nice old Oak pollard in Warndon Villages, Worcester. The spec was a 30% crown reduction, partly to take weight off those large old limbs but also because of a questionable subsidence issue on a conservatory at the house on the left of the picture.
Climber was Matthew, all work carried out with a Silky. Think we ended up with about 25% in the end, anymore and it would have looked awful.
The work was carried out without prejudice.
I’ll look at the tree again in two years time and see if there is an inner crown is developing, if there is we’ll take a little more off.
  • Replies 27
Hortlink, research sugest 70-90% reduction required to have any impact on tree induced subsidence.. So what you've done is fine for endweighting and looks good but if your doing it to prevent subsidence it's not nearly enough..
70-90% reduction, getting to the stage of pollarding it arnt you when you talk about Those kinda numbers? :)
Not my numbers, from the BRE:
Pruning trees to reduce water use
Summaries of research; conclusions and
recommendations IP7/06
Hipps, Atkinson and Griffiths
Recommendations
● For consistent soil moisture conservation,
severe crown reduction of 70–90% of crown
volume would have to be applied. Reduction of
up to 50% crown volume is not always effective
for decreasing soil drying
● To ensure a continued decrease in canopy leaf
area and to maximise the period of soil moisture
conservation, crown reductions should be
repeated on a regular managed cycle with an
interval based on monitoring regrowth
● Crown thinning may be aesthetically desirable
but is not an effective method to control soil
drying by trees
Basically reducing trees to prevent subsidence is not an option..
