  • Replies 156
It is! Clearly an expert. What did you think? Has it convinced you to buy Rotatach Chains?
ย
Well I know the difference between a hectare and a hector if that's anything to go by.
I wouldn't buy it based on that video no, friends of mine are trying some at the moment and gave me some files to try, but I tend to use13/64 not 7/32.
I only use chipper profile chain, not sure if you do it in that ?
@TimberMan That is great, hopefully your friends tell you good things about them. We have been getting lots of good feedback about the files also.
ย
I have removed the part about hectares, since it seems to be detracting from the video.
ย
Thought it was the bit about Hectors actually ,but hey.
In fairness they did say the chains were doing ok, but as I say I only use chipper/semi chipper and am not sure you do that ?
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
