25" Sugi light type.
Gerbutt
  • Replies 21
The bar might be wider than the original. 84dl is correct for the Stihl bar.
It shouldn't be a big deal for your local shop to pop an extra link in for you.
Aye Joe they said they'd make another so that's good. It's just a tad confusing why it's like it, on fr jones site for that bar it says 84dl too! I have a 7 rim on so that should be correct. I have a 20" Sugi bar and the chains are right for that at 72dl!?
Yea , What I meant was I know 84 is correct for a 24" Husky so assumed it might be a few more for a Stihl 25"
Stihl and Husky confuse the issue a little because the 24" Husky is the same length as equivalent 25" Stihl - they just like to call it different lengths! But bars are same length and take same chain.
What drive rim/sprocket are you using?- possibly it is an 8 pin and this may mean another drive link for the Sugi bar....
[ame]
[/ame]
Apologies for vid angles.
Really with a new set up on an 8 pin you need an 85 drive link chain.
:001_smile:
:001_smile:
I will come clean and say I did not know that Rob ! Always used a Husqvarna in that size and took it that the Stihl was longer by an inch . Every day is a school day as they say ! Oh by the way op says he is on a standard 7 pin .
:001_smile:
Yes a MS661 with 28 bar runs a 92 Drive links on 8 pin rather than the standard 91
