Alternative to the GX390 engine
Wolfie
  • 5 weeks later...
  • Replies 25
Well after much deliberating, swaying back and forth between getting a Honda or other, I decided to risk it and bought myself a Evo420 14Hp engine. At £200 inc vat it's less than a third of the price of a GX390 so if it lasts a year or more, i'll be happy.
The fitting was very easy, as advertised it's been designed as a direct replacement for the Honda so mounting holes and drive are exactly the same.
It sounds sweet but its got a full day of grinding tomorrow so we'll see how it holds up.
I'll try to remember to update the thread in 6 months - hopefully with good news that cheaper engines are indeed a viable alternative.
  • 1 month later...
Just ordered a Evo420 14Hp engine...Let's see how it goes....
How's yours Wolfie
How's yours Wolfie
The performance of the engine is still very good. There are, however, a few other niggly problems. The fuel tank cap does not fit well, so it leaks a bit when grinding deep or during a rough transit, the exhaust has fallen off a few times due to the cylinder/manifold studs rattling out and the pull cord has snapped once already.
Considering the engine costs less than £170, i can put up with a few small fixes.
Not a fan of Chinese engines or generators. But have had some success by very regular oil changes. Change oil after first day's work. I would then tend to change every 25 - 50 hrs running. The engines seem to drop a lot of shards and shavings especially in the first few hours.
is the Honda engine on 50 hr intervals as well
Can you not fit your old Honda tank and cap to the new engine?
Yes, i was thinking of doing that when I get some spare time. I've already robbed a few things off the old engine - exhaust fume directional cap thingy and the oil drain pipe.
  • 3 months later...
An update on the alternative to Honda situation - don't buy Chinese, at least not the Evo420, it didn't last 2 months. I hope that yours is doing a bit better Redmoosefaction.
I've had a Subaru engine on the machine for a few months now and can recommend these.
Sent from my iPad using Arbtalk
