Dead beech dismantle
Tom D
so you telling me with a large branch with a lot of weight on it..you are going to put a deep under cut in?! don't you think you will get your saw jammed.? doh!
very good video..but all I am saying is i would have put a mouth in those big bits or took a bit of weight off the ends.
I am sure there are lots of mistakes i make when climbing..and i don' t mind if i get told i am doing something wrong / better way to do it as it makes you a safer better climber.
Even putting a mouth in you can get your saw stuck in the kerf.
I thought Toms cuts were good i wouldn't of bothered putting a mouth in on those heavy bits if i could get away with it less cutting that way, and the fewer cuts you can make with a big saw the better imo.
The only criticism i could see is poor or lazy grip on the saw what ever way you want to look at it. Other than that nice job.
Edited by Marc
  • Replies 41
:confused1:WHO said "deep under cut??????????:confused1:
Not sure the "doh!" was called for :thumbdown:
I can't spot the bit with the lazy grip, what time was it?:001_smile:
Once again thanks for the comments guys.:thumbup1:
Good Vid Tom, thanks for taking the time to share it with us. I’m thinking of taking the plunge and getting a cam also. Don’t think we’ve had many take-downs filmed from a MEWP yet! lol.
One thing – I make my guys wear their hi-vis while I’m up in the tree, they stick-out like sore thumbs then – always good to know where they are. :001_smile:
