Dont have the hydraulic oil filled to max and have a can of diesel in the truck rather than the chipper tank. Not ideal i know, but an option.
Would get it closer to legal but not a 50kg saving.
  • Replies 51
It's not something I have had direct experience of but one of our contractors was stopped and weighed with a trailer behind a 4WD. Despite almost certainly being overloaded on the nose of the trailer because the sum of the axle weights was under the GTW he avoided a penalty. Had they separated the trailer it would have been over the trailer gross weight. So on that basis and not knowing the legal position a 800kg trailer with 50kg of nose weight may get past without comment as long as the tow vehicle has the 50kg to spare on its MAM.
Good point.
Why don't you add a second axle, or run it up onto a tandem axle trailer?
Are you trying to keep below the 750kg limit and licence??
If so just do the test?
Replace the single axle with a braked single axle.
Unless the tow vehicle is over 2600kg (ish to allow for extra weight of brake kit) then they still wont need a trailer licence.
New build trailers (and this would be one) should go through an SVA test now.
Not sure if this would be a new trailer or an alteration of one.
Also trailers that are fixed plant could be exempt anyway if I am understanding the regs correctly.
Edited by Justme
This is a quote from the guideance.
Its is very open to interpritation.
1.9 When does IVA not apply?
• Agricultural or forestry tractors, their trailers and interchangeable towed machinery, together
with their systems, components and separate technical units and trailers designed and
constructed specifically to be towed by them.
• Quadricycles.
• Tracked vehicles.
• ‘Incomplete’ vehicles (except until October 29th 2014 in respect of an incomplete Heavy Goods Vehicle)
• Old vehicles (i.e. passenger cars and light goods vehicles over 10 years old and large goods
vehicles over 25 years old).
IVA does not apply but is optional for the following :
• Vehicles designed and constructed for use principally on construction sites or in quarries, port
or airport facilities.
• Vehicles designed and constructed for use by the armed services, civil defence, fire services
and forces responsible for maintaining public order.
Mobile machinery.
Can a trailer with a machine permanently fixed to it count as mobile machinery?
I will have to ask DVSA re this.
I would have thought that, by definition, a trailer is something that carries something (goods). Therefore a chipper isn't a trailer but mobile machinery. A tracked chipper in a trailer would be a load and wouldn't be.
