:001_rolleyes:
Here's my 1954 Ferguson TEA with a 3 ton winch mounted on the rear axle. The trailer is homemade, 3 ton capacity with pto drive and a wirecrane.
Me likey :thumbup:
Ste
(i) Is that another Ferguson back end, used as a trailer drive axle.
(ii) What is a wirecrane?
cheers
M
cheers
M
Yes, it is the rear axle from a fergie that we have used. It is held in place with 8 bolts. 2 At the rear pto, 4 at the fender mounts, and a bolt on each side where the pto lever usually is located. The pto shaft, hydraulic pump and cylinder was removed and replaced with coverplates. Internally we had to fabricate a pto output from the differential that is bolted to the front coverplate. 2 Pto shafts are used to transfer power from the trailer to the tractor.
A wire crane is basically a boom with a winch that helps you lift the logs.
