On the whole, tractors fitted with front pto run them in the opposite direction to the rear. Occasionally manufacturers can set up to run the same, or, you can fit a gear box to reverse the drive to make it the same as the rear.
Without "anticlock" running most chippers, processors etc is a no go.
PTO runs in same direction as engine front and rear as a rule, so front drive is opposite to rear as drive is picked up from the crank at either end. You need a reversing gearbox to drive standard implements on the front.
Really????:confused1::confused1::confused1:
Really????:confused1::confused1::confused1:[/quote?
Pretty much, yes. The crank turns in opposite directions if viewed from front or rear, and this determines pto rotation.
:thumbup::thumbup::thumbup::thumbup::thumbup:
Perzactly
I did try and make my comment as sarcastic as I possibly could, but obviously missed by some.
The point was, I'm sure someone else had given an explanation in the post before.👍
Oh right, sorry, I just fawt you was a bit fick!
