Can anyone help me, need to bore out approx 100mm into a 8 inch deep piece of silver birch to drop on a tea light for our wedding table centrepieces ?
Sort of after this affect as seen below
  • Replies 21
The picture does just show one made out of bark but I'm wanting to leave some of the heartwood in and also not go right through the bottom, just had a look at those forstner drill bit sets at screwfix, only £39.99 so think that may be the way forward
How about drawing your circle on one end and using a narrow and low tpi bandsaw blade to cut it out vertically, breaking through from the side to start it. You can reglue it once it is dry and then cut out your shapes in the side. Silver birch when wet is quite soft so it shouldnt be too difficult.
Mike
If you are in SW Scotland, bring in round and I will put it in the lathe for you, metal cutting lathe but will still do the job, did something very similar to make a red squirrel feeder.
If your in Norfolk happy to turn them out for you. The bandsaw idea also work well, there are some videos on the www of hidden compartment's being made in logs for storage of spare keys etc. I think it will depend on your access or not to machinery and how much time you have.
S.
