Hi all,
As well as working for my Local authority i also subbie for 2 local companies.I have a basic rigging setup capatan and block etc which i seem to be using more often of late.
My problem is the ground guys i get are usually not used to rigging trees and have little to no knowledge of a rigging system.
Its difficult to get guys good at lowering when i only work with them now and then.Is there any other system i could utilise to make it easier on the ground guys...xrings perhaps.
Im open to ideas not critisism please
Thanks folks
  • Replies 35
Nope, not in my (many years of) experience, the only way to do this is train someone to do the job properly
Make a little rigging model
[ATTACH]205188[/ATTACH]
So you can explain easier and faster.
Now THAT is a great idea - I know to a lot of us its obvious, but when theres a trainee or a 'slow' or unfamiliar groundie it's just the job. :thumbup1::thumbup1:
I can see the sense in that but rigging newbies tend to be pooping themselves and would have to face the wrath of the boss/client/workmates taking the pee if anything goes wrong.
They lack faith in the climber/rope/bollard/ability and generally end up with way too much friction in the system. As son as you are a couple of feet away they start questioning themselves and generally not having a good time of it.
Good rigging isn't something most people can learn by "suck it and see"
A model is a good teaching aid but if the fert hits the spinner, you immediately come to the question of "working of instructing" I wouldn't want to be pointing at the model and saying "well I told him what to do"............. :001_rolleyes:
As josh says .... A fixed bollard is almost fool proof even a floating rc2000 would be a a lot easier to get there heads around than a portawrap then all you have to do is shout how many wraps and hold or run.
