I had a similar problem a few years back when I ran an old 4x4 on biodiesel (most probably recycled cooking oil). Got a cold snap and started running very badly. When I pulled the fuel filter, there was a massive blob of jelly blocking it.
  • Replies 48
whits stuff ,bit like jizz
I was talking to Alan Oldfield this week and that Forestry spec 360 had a n episode of poor diesel and it cost £5k to repair! New injectors, engine flush and new oil and filter. Tank flush and new filters, it only got going enough on site at the 3rd attempt to get it recovered!
stays like jelly ,got what ever it is out , & chipper ok
I suspect some condensation has settled in the diesel somewhere then, I only ever had this problem with one tractor and I could see water build up in the filters which had glass bowls, drained it and thought no more but eventually the tank filter blocked. There was a poor joint between the filler tank and cap which let a bit of water in.
I read the problem is becoming worse as biofuel is added to diesel as the bugs grow better in it but the cause remains water in the fuel system somewhere. I think the marine water displacer is simply anhydrous methanol, not that I know where to get that.
had both chipper pack in , fuel is out off a barrall thats just been started,its like a white snotty gluppy stuff & the diesel looks a bit milky not clear ,
any thoughts
Sounds like its time to clean out the tanks and barrels Johny. Without the water you should not really need all the other Gizmos. This gear is worth a look http://arbtalk.co.uk/forum/maintenance-help/94633-nifty-fuel-water-test.html
Bob
