Best way to clean carabiners??
WoodED
Hi all,
Cleaned out all of my climbing kit the weekend to find all of my spare Isc carabiners are gunked up with crud and won't shut properly or the gate jams, I tried soaking them in hot water, opening them repeatedly in the water, tried a little bit of fairy liquid but I've not had any joy,
So was wondering what everyone else uses to clean out there biners
Thanks
Ed
  • Replies 24
Duck Oil displaces water and keeps the barrel running smoothly. Application of a small drop will usually bring even the most stubborn carabiner barrel mechanism back to life.
In contrast, graphite powder does have a tendency to clog up and harden when a little bit of moisture is introduced to the equation. The more graphite you apply, the worse the problem becomes.
Taken from here. http://treetools.co.nz/_blog/Treetools_Blog/post/Liquid_carabiner_lubrication_surpasses_graphite_powder/
