the 362...
stratocharged engine
same power output (4.6bhp), weight increase from 5.6 to 5.9kg
hd airfilter with pre-seperation (read husky style)
spring anti-vibe mounts (read husky style:001_tongue:)
one piece filter/cylinder cover secured with three torx bolts
the future is here
I'd better buy a 361 quick then! What is it with power to weight ratios getting worse??? :thumbdown:
  • Replies 24
I dont know, when are you ever out cutting without a combi spanner?
I find the quick release air filter cover on the 441 quite tricky to get off without a screwdriver anyway....
Could that be because you tighten them up with a screwdriver in the first place? :001_tongue:
