Ideas wanted for rain screen
Woodworks
Have lots of low sheds with stacked logs in them. Southerly gales blow right into the front and soak the logs. This is not a problem from the overall drying process but have had a a few mutters from customers when delivering freshly rained on logs. Thought I would just get some tarpaulins to hang under the roof to stop the wind blowing in but seems there aren't any heavy duty tarps as small as I need i.e 1.6-1.8m high.
Was wondering about windbreak mesh and if it would stop most of the rain going in. Anyone tried this?
Thanks
Thanks
Can you not make the overhang a bit longer or is it horizontal rain ?
Windbreak mesh does stop the rain. The other thing to use is old curtain side material. Some times the curtains get changed because they are damaged but still look fresh.
Have got some but they are well oversize and when just fixed at the top can get blown back over the roof. If the mesh works would make up a lightweight frame with the mesh attached and place it in front of the bay that's about to be used.
Edited by Woodworks
