Is it possible to have the ignition coil of a saw repaired or is a new one the only option?
I once managed to drive off the laminated part of a faulty coil and replaced it with a coil off another machine and a trigger unit so a Stihl 012 fitted a Dolmar 116Si!
Modern coils have some whizzy electronics in them - stick a timing light on an old and then a new machine and note the difference!
And which machine are you having trouble with:sneaky2::sneaky2::001_rolleyes::lol:
This sounds interesting you know what I have in mind then ,do you recon there is a fix ?
Well I am glad the piston/cylinder are OK. I think I right in saying that this saw doesn't have a contact breaker and the coil is a smart unit with built in trigger but fixed ignition timing.
If it is the latter then it is worth trying a very small coil to flywheel gap, try using a piece of thick grade A4 paper and spin the engine over with gusto and see if you get a spark. From past experience, you may get a slight spark and then bugger all if the coil is bad.
If the coil is bad, remove it and lets get a look at it. I read a post on AS and it stated thet there are three flywheels and three coils in the history of your @*&%$ machine but I do have an old Dolmar Stone cutter - possibly something we can do here???
