  • Replies 42
im not sure it matters on the sizeof the gap between the rings as long as there is a gap for the rings to be pulled into by your climbing line
nice looking friction saver there bob, splicing something other than hollow braid is something i keep planning on learning
tbh i have tried that but imo having a pulley that fits through the ring so it proper cinches up seems better
anyone that wants to can splice
but imo you have to want to
and then put the time and sore hands into making them easy to do
i was going to say splicing is easy but tbh splicing is easier now have got it sorted:thumbup:
i would think it would john, i reckon the bigger the gap the better, giving more force into the squeeze on the stem, but not too much so the rings are around the corners so to speak. i reckon a 10-2 position would be best:thumbup1:
i have a rope guide so its not an issue for me
hoping to get a course going down here with nod at some point to give me the basics to work from
  • 6 months later...
2 to 6 inches....
love this set up! its ace.....i was wondering thou, (and excuse any ignorance, im new to this!) is there anything stopping you adding another prussic+ring to this set-up to put a second climbing line through? so if the s*** hits the fan your groundie can get up to you fast! (sorry if this is a bad discription!)
This may just be too many lines in one tree, but if i get stuck up a pole i think i'd rather too many than too fue!
I see. Though the advantage of a figure of 8 is that you could descend on it nice and smooth if you had to get to the ground at a moments notice (e.g. to rescue another climber) and as I said before the groundie could lower you. You just have to make sure that the figure 8 is locked off when working and a rescuer would have to be able to unlock it to get you down.
deleted!
Edited by Tony Croft aka hamadryad
was bored and should have known better!
evan better ! dont put your self in a position wer a rescue is requried !! think ,think think ! work postion !think safe ,isit more hast less speed ? it will come to all you youngsters intime :biggrin:
