Seen some rigging rings on treekit, question is what size rope do i need for the rings? i was planning to attach them with a fishermans, i know this is not the strongest but will only be used for light rigging/ redirects.
Yeah same as, just different brand on tree kit i think, my friend has some attached with fishermans and have being fine, they wont be hammered.
Just splice them , locking brummels are super easy.
The rope will break before the ring so just choose the appropriate diameter for the application
Looks a bit more challenging if you want to splice a ring into each end though!
Just do a non locking brummel with a large bury and lockstitch.
to be fair i think your limiting yourself with a non adjustable rig and ring though
I spliced up a ring on a bit of icetail to use as an adjustable rig nd ring cambium saver on any of my x ring redirects , multiuse , adjustable and retrievable.
You can do a locking brummel at both ends it's just a little trickier to do, watch this and it'll show you,
I really like my beast ring and ring.
