Over the past few months I've thought what would make the best around chipper putting all manufactures together, I came up with this ideas, all just for fun, obviously it's never going to happen. Please add or remove as you see fit! As follows:
Ifor Williams to make chassis using Knott brakes and coupling
Schliesing to make main chipping unit and roller setup (235MX it's not too heavy) but with blade setup and open flywheel from Jensen.
Timberwolf style rollers, removable blades.
Kubota 4 pot, long stroke, no turbo. Overrun clutch
Jensen folding infeed hopper, stop bar the curved one from A540 and touch buttons.
Tunnissen discharge chute assembly, simple but effective.
Greenmech finish and powdercoat process.
Greenmech electrics and feed control/ button start.
Direct drive hydraulic pump.
3x drive belts.
I reakon it'll sell, may cost a lot :thumbup:
Why not mount it on a turntable onthe back of a 3.5 GVW chassis cab (Landy, Nissan, your favourite). Then seek advice from Mr Ploggs on a suitable 3.5 ton tipping trailer and Robert is the brother of one of your parents.
This made me think of the Top Trump cards we used to have when were kids, we should make a Top Trumps Chipper card set, this would help me decide what chipper to buy.
Categories ?
Length
Height
Wight
Hp
Chipping diameter
Top Speed
Chip per hour rating
Range/fuel capacity on one tank
off road capability/tracked etc..
What makes you think Plogs would know anything about 3.5 ton tipping trailers?
Read more
