Stump planers for Mini digger
Matthew Storrs
  On 28/09/2015 at 21:19, Matthew Storrs said:
I paid roughly £1650 (inc Vat and delivery) for the x2500 drive unit and also a 6inch and 12inch auger with tungsten carbide tips. Really brilliant well made kit from Augertorque- would work well on a 2.5tonner etc
Expand
have the same including the grinder. It literally chews the stump to bits nice and slowly so safe and easily controllable.
  On 10/11/2019 at 23:54, dumper said:
Tried one on my loader didn’t wasn’t impressed not enough push down far quicker with grinder was difficult to get whole stump kept slipping of
Expand
When I bore holes on hard ground I add tractor weights to auger frame to get more down force so would do the same.
  On 11/11/2019 at 09:21, Stumpy Grinder said:
I can't see the blades staying sharp for too long once they hit the dirt, and they would need to be very sharp to cut cross-grain as they do? Also relies on being able to get a mini digger in which is not always possible and tracked machines aren't exactly lawn friendly!
Expand
Stump grinders go blunt when you hit dirt, and aren't a lot of grinders on tracks.
Expand
My auger will bore through Tarmac I just found the lack of control and vision plus the amount of weight required meant that a dedicated grinder was far better. avant and some others used to do a stump grinder with its own engine for the front a better idea for a low powered loader
Read more
