Here are the pictures of the final WOODY lowering device
As i said i would put them up sorry taken so long and as some of you might know last Thursday night my unit got broken in to and took all my saws and hedge cutters so as i got some time on my hands i thought i would get them on here for you guys
There will be a video to follow at some point
It is zinc plated so no need to worry about rust
It has a safe working load of 1250kg this has been shock load tested so no need to worry (we are bringing another device out that will have a safe working load of 2000kg for your big boy jobs in the future just doing final tests)
It has two 5ton straps that come with it plus a bar to tighten the ratchets
It is British made
You can work 220 degrees around the base with the lowering device
If you wont to have a proper look at this device touch it, feel the wait throw it around hopefully it will be at the:-
IOG Saltex Show
Windsor Racecourse
The Racecourse
Maidenhead Road
Windsor
Berkshire
SL4 5JJ
England
IOG SALTEX - grounds care, landscaping, sports amenities and estate management event
Witch is on the 8th-9th-10th September
Have you got a WOODY yet?
Just one more thing to add i have said before this is just a cheaper lowering device that works just plane and simple if it helps people out great
Any questions please ask
  • Replies 44
great stuff mate , brian and i are still using your origional that he bought on ebay and so far we are really happy with how it preforms . well done mate
glad you are happy with it done anything big on it yet?
does it dig into the tree?if there is a heavy weight on it near the outer end will it fold up the way??
it does a little but we are just waiting for a rubber mat to be finished that you put between the woody and the tree we have been using a bit of carpet with ares at the mo witch works fine
the weight is always on the back two pegs nearest the tree so there is no movement in the unit i hope that answers your question if not i may have read your question wrong
how cheap is cheap:biggrin:
cheaper than some others
£259-99 with everything it comes with we were hoping a bit cheaper but there is alot more involved than you think when you wont to sell them once we sell more of the the price should hopefully come down a bit but just depends on how many go
