Simple idea - but how about if you had a carving bar with holes drilled - and then you could screw a stop or similar and this way it would control the depth of cut - carvers do you think this would be handy?
:biggrin:
Hi Rob,
Looks like it may work, don't know much about carving other than what I have watched,
How about cutting a slot in the bar then having a bolt with two washers so you can slide up & down the bar?
N
Limited uses I would think Rob. The fiddling around changing the stop constantly would soon get tiring. I'd then just be using the series of holes as a guide.
Markings on the bar that were not painted and wouldn't wear off would be a better idea, but more consistent measurements than on the Stihl bars.
25mm (1") would be good :)
Edit: Just seen your pic has 1" centres!
Thanks for comments/feedback... so even without the bolt in there the drill holes could give an idea of depth?
Like the idea of a long slot as well....
:001_smile:
:001_smile:
Yes, and they wouldn't need to be as big as those in the image.
I normally use the writing on the bar as a guide, but once it's worn off it's all guesswork. (It's mostly guesswork anyway!!! ;) ;) )
Interesting idea Rob, why not machine a slot instead then you have infinite adjustment, could be ideal for oak frame work and the like, possibly have some rollers instead of the bare bolt..
I use a G-clamp for that, but only when it really matters or when I have a lot of cuts the same depth as it's added hassle.
Little nicks with a 1mm disc at 20mm intervals for measuring.
It would be better than a G if you could move it with some sort of quick-release, so it would take no time to adjust/remove.
Read more
