€400 Worth of tyre from the compact tractor decided it had enough yesterday, leaving us to handball tonnes of cord.
Goddammit!
Ouch.:thumbdown:
Bob
Ten tonners turn this time.
A clatter and a bang after pulling out of a job with the loss of some brakes revealed a ripped off brake pipe and a stabbed rear tyre.
Something else must have got inside the drum because one of the adjusters was bent and there was a lump out of the wheel cylinder, also the grease seal had been torn which in turn contaminated the brake linings.:thumbdown:
Edited by aspenarb
Lots of new bits because the things in for test in a month so with brakes and balance its an axle overhaul.
The seal was a funny shape on the outside so I spun up a press tool to push it in the hub ( too dear to butcher in with a hammer at £50 each)
All back together
And made up some new brake pipes for the axle. Its the 6mm stuff so you need a bender or it just flattens out.
Edited by aspenarb
All back together
bob
what do you prefer
1,doing trees
2,or fixing kit that yr staff break :biggrin:
