Ash, worth milling ?.
Alycidon
I have an ASH stick, about 32 - 34 inches diameter. Perfectly straight and parallel for about 9 feet. Storm blown tree, got some heart rot in the lower part.
Was thinking of milling it for mantle pieces to sell in the stove showroom when dry. How does Ash mill, is it likely to split?.
A
I milled some 7x1" Ash planks from similar logs nearly twenty years ago with my Lucas Mill. Planed them up and they still look good as a wooden suspended floor in an old garage I converted into a living room 18 feet x 24 feet.
The floor is very hard wearing and does not show stiletto heel marks!
I use straight logs for anything from repairs to one ton boxes to making 3"x 8" eight foot wide beams to go on the front of my grain pusher. This is much gentler than the steel equivalent on the floor of the grain store and on the walls when I misjudge my turns!
Chainsaw milling I presume?
Ash can be a bit harder to mill than you initially think it will be but it mills well enough and dries nicely. If you are lucky there will be some colour in there - probably not much grain if it's straight but good for the Scandinavian look!
Alec
