Eliet Super Prof shredders
GardenKit
  • Replies 31
:thumbup1:
So, do chippers like the CS100 handle green waste, or do they only like woody stuff?
How do they handle steel and stones?
Ok with garden stuff if not to 'earthy' grass cuttings and leaves will just come out the other side. Found if lots of green material feed some nice wood in with it to give it something to work on.
No has to be debris free.
Lets clear up a bit of confusion. The picture on the first lage of two machines on a trailer, are in fact two different models. The video of one working is the prof5, which is cheaper than the super proffessional 2000 which has just been redesigned and relaunched. If you saw the later in action, you will see its a far superior machine.
as regard to wet conifer, if you shred with timber, it does not block. You can install a larger screen which is great for bulk reduction,better than dicing on the back of the truck.
what remains to be seen though is how this new machine compares to the old. It was great having a conveyor to discharge the shreddings. Having a blower can only mean more blockages, and it takes power away from the engine. Can the new blower cope with a larger screen fitted for example.
Now I have owned an eliet, I would not go to another narrow access chipper. They are superb
Thanks for that positive post, Mr Dig-dug-dan. Its good to hear someone say it does work, rather than those who speculate that it will not.
You are correct, the machine on the front is the new model. The blower is not so much a blower, as a 'thrower'. The material that has passed through the screen ends up in quite a large void. There is a double sided auger which brings the material to an accelerator chute in the centre which literally throws it up the chute.
This uses less energy than a traditional blower.
I have not seen it in action, but I need to get a few interested prospective buyers together and organise a demo session. Luckily the SW rep lives only a few miles away.
  • 3 months later...
