  • Replies 24
Even air dried sycamore gets that tired look, traditionally each board was stood upright against a wall separately or in racks with spacers at very top so only end few inches get sticker stain.
I can only speak from my experience, here goes....
My boards were a solid two inch thick 8ft long 2-3ft wide. I leaned them in a draughty Yorkshire board clad shed with block walled base 5ft high despite the size a couple did warp and twist a little, I turned them and kept an eye on them for a few months (3-4) before stacking them the regular way with weights on top.thr kinked boards did not straighten in my case.
If look it up in the search bar sycamore seasoning drying. You will find otherthreads and comments.
As far as I'm aware up ending is only need for summer felled sycamore and once the sap has stopped running out they should be stacked in the normal fashion.
