What generic tools/ others items would you recommend to keep in the truck or van for a towable wood chipper?
Both general maintenance and for emergencies.... 🔨🔩🔧
  • Replies 27
Spare drive belts for flywheel and for hydraulic pump (inexpensive but priceless in the middle of nowhere).
Jump leads - unless you have chipper which can be bump started.
Wire (as suggested above)
Logs to hold up the infeed rollers if you need to de-clog.
Logs for wheel chocks if the handbrake will not hold in reverse on hill.
