moles
Guest the cleaner
I have one of the little beggers, took that much soil from under my paved path, one of the slabs collapsed. Think I need to get rid of him!
I'll put a couple of traps in with the next broken saw I send your way :) remind me!
  • Replies 27
Hi
Piège à taupe et anti-taupe. Destruction rapide de nuisibles taupiers.
Works a treat :biggrin:, may not be available your side of channel tho.
Yes, it will only be one mole, they can cover an area the size of football pitch
They do have very sensitive smell so if you expose each hole & put a little diesel down it generally moves them, once gone try & cave in all the runs.
N
I tried traps, always forgot where I'd buried them! Dog poo down the hole now, that sends 'em topside then the dogs do the rest!
I doubt it would be propane-air as that has a narrow band of fuel to air ratio that will ignite around 1:14. Acetylene or hydrogen would be better choice.
Just googled the manufacturers website, it uses propane and oxygene
Ok that makes sense as increasing oxygen fivefold makes things much more flammable, witnes one of the Apollo moonflights
Thanks Joe, I have got one on order and hope that will do it, I did try a big French banger but just covered the lawn in soil and annoyed the neighbours:blushing::lol:
Hope you ordered the tunnel trap and not the one that sticks out the ground!
If you catch one, stick it back down the run and leave it, as a message to the rest!
